Activity › Forums › Adobe Premiere Pro › Interpreted Fields as Progressive, Getting De-interlacing Artifacts
  • Interpreted Fields as Progressive, Getting De-interlacing Artifacts
    Posted by Michael Zahara on March 23, 2016 at 5:14 pm
    Hello, my footage is from a HF200 camcorder. I recorded using Progressive Based which is actually Progressive Segmented Frames a 60i.
    I look around the internet and I had to Interpret the fields as Progressive because Adobe Premiere is confused since the container is 60i.
    Howver, on closer inspection, I notice there is interlacing going on, on moving objects. Please look at this image as it is driving me nuts!
    I am using Adobe Premiere Pro 6. This screen grab was taken from exported Cineform codec.
    Please zoom in, and look at the face. Seems like I see interlacing.
    ** UPDATE ** I noticed this using Cineform Codec. When I sued Avid dnxhD, this I didn’t see it.
    Are there any Cineform decoder settings to follow? I Have Cineform Decoder that Pops up with a red icon, and I use Windows Media Play Classic.
    Michael Zahara replied 10 years, 6 months ago 2 Members · 9 Replies
  • 9 Replies
  • Chris Wright
    March 23, 2016 at 7:13 pm
    I believe its a certain cadence pulldown from 24 to get 60i.
    is the advanced dv pulldown greyed out in premiere?
    do you have a mac or pc?
    Apple compressor:
    reverse telecine pulldown Most likely 2:3:3:2 or 2:3:2:3
    After Effects:
    advanced pulldown WSSWW
    avisynth:
    DirectShowSource(“hanger.mts”, fps=29.970, audio=false, convertfps=true)
    AssumeTFF()
    Telecide(guide=0, post=2, vthresh=30)
    Decimate()
  • Michael Zahara
    March 23, 2016 at 7:36 pm
    Hello, I am using a PC.
    Also, I am not working in 24p. I Choose the 30p on my camcorder HF200.
    As stated, Cineform gave me this problem, not DnxhD, haven’t tried h.264 yet.
  • Chris Wright
    March 23, 2016 at 9:49 pm
    that sounds like a bug if you didn’t change the field settings.
    are you rendering fields off?
  • Michael Zahara
    March 23, 2016 at 9:52 pm
    All is set to progressive. Even in Export.
    I rendered in Cineform > Then to H.264. Nothing showed in H.264. Must be in the decoder… But what……
  • Chris Wright
    March 23, 2016 at 10:32 pm
    ok, try rendering a few frames to DnxHD -> then to Cineform-> then finally to h.264.
    DnxHD should delete interlacing rendered as progressive bugs.
    This should isolate where the error occurs.
    There’s a very small chance that cineform may be ignoring field settings.
    Are you re-importing back into the same project sequence? Try a
    whole new project file for reimporting as well. purge cache too just to be safe.
  • Michael Zahara
    March 23, 2016 at 10:44 pm
    I imported the new Cineform file as a new Project ofcourse.
    I will clean the cache or purge as you might say.
    Now the problem going from dnxHD to Cineform is it will degrade the picture more. Cineform is actually a better codec in my opinion than dnxHD.
    So what you saw were interlaced frames? Not so visible but something didn’t look right.
  • Chris Wright
    March 23, 2016 at 11:03 pm
    yes, you are absolutely right about losing quality. This is a test for a bug.
    Obviously if it works, render out a lossless 10 bit non-cineform, then cineform. I wouldn’t even call this a workaround at this juncture because in reality, no one has time to render out twice.
    That’s why a new project and clearing cache might reveal more possible solutions.
    If my concerns are founded, please file a bug report to adobe so that no one else gets frustrated.
    https://www.adobe.com/products/wishform.html
  • Michael Zahara
    March 23, 2016 at 11:30 pm
    Hello, I uninstalled Cineform Decoder in Controler Panel by searching for “Cine”, and now the problem is gone.
    Can anyone explain?
    I have Go Pro Studio installed. I don’t know which codecs from this are there
  • Michael Zahara
    March 23, 2016 at 11:33 pm
    Now that I unstalled it. In Windows Media Player, it wont play Cineform now. Just audio.
    Windows Media Player Classic does. I heard somewhere that Cineform doesn’t play in Windows Media Player. Can someone else chime in here?
