Activity › Forums › Adobe Premiere Pro › interpret footage
interpret footage
Posted by Martin on September 7, 2005 at 11:38 amHi
If you shoot footage on a pal camera and then interpret footage to NTSC, will the quality be the same as if I shot the footage in NTSCSteven L. gotz replied 21 years ago 4 Members · 4 Replies -
Tim Kurkoski
September 7, 2005 at 4:02 pmNo. Slowing the footage down repeats fields/frames to fill out the extra time. It will probably look slightly stuttery (but acceptable, like 24fps film stutter). Shooting actual NTSC will look smoother and more natural.
Martin
September 7, 2005 at 6:46 pmOk so what are my options? I need a camera that can record in high-quality 4:2:2, with Switchable NTSC/PAL….got any ideas?.
Martin -
Steve Freebairn
September 8, 2005 at 2:27 pmYeah, get the new Panasonic P2 camera and then use the overcranking/undercranking feature to record at 25 fps when you need Pal. It might actually work, and it can do 4:2:2
Steven L. gotz
September 8, 2005 at 5:44 pmThere are cameras, like the Sony HDR-FX1 that can shoot 25fps or 30fps – would that be what you are looking for?
And there are software programs like Canopus Procoder that can make the conversion. It might be easier if you were converting both to 24P, but trying to make 25fps into 30fps will by its very nature, be less than optimum.
Steven
Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
