Activity Forums Adobe After Effects Interpolation between still images
  • Interpolation between still images
    Posted by James Sanderson on December 6, 2012 at 1:46 pm
    Hi there I am new to after effects but I need to find out how to create interpolation between stills on the program. I have attached a video by Morgan Beringer which shows the effect Im trying to create. still images are used and stretched across time with a variety of time-interpolation methods to create abstract moulding and warping of the images.
    The results are taken then edited them together and put them through 2-3 more renders worth of time-based effects, lighting, blurs, colour, etc. (but I dont need help with this part, just the initail process!)
    Can anyone help please!?
    Many thanks
    https://vimeo.com/53071943
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Lori Freitag replied 13 years, 8 months ago 3 Members · 2 Replies
  • Walter Soyka
    December 7, 2012 at 3:12 pm
    [James Sanderson] “still images are used and stretched across time with a variety of time-interpolation methods to create abstract moulding and warping of the images. “
    You should be able to precomp the sequence of your images, then use the precomp as a source for Timewarp or Twixtor. Adjust time by source frame instead of speed for more control.
    I’d think the quality of this method will greatly depend on the source images.
    Walter Soyka
  • Lori Freitag
    December 12, 2012 at 11:17 pm
    You can watch this tutorial:
    https://library.creativecow.net/freitag_lori/Creating-Seamless-Transitions/1
    It will help you to understand how to use RE:Flex to interpolate between still images.
