Activity Forums Adobe After Effects Expressions interpolate parameter / adjust rate of change – without keyframes
  • interpolate parameter / adjust rate of change – without keyframes
    Posted by Dirk De jong on September 26, 2017 at 3:14 pm
    The Turbulent Noise and Fractal Noise generator effects don’t have an option to auto-animate the Evolution at a specific rate (I wish they did). I’m building a comp in which I’d like to be able to simply control the “speed” or rate of interpolation for the Evolution parameter in a single place – probably with an expression control applied to a null at the top of the comp (without having to use keyframes etc.). Is this reasonably possible using expressions ? Thanks for any info and apologies if I’m missing an obvious answer (I did some googling on it and didn’t come up with much)
    Dirk De jong replied 8 years, 10 months ago 2 Members · 3 Replies
  • Dirk De jong
    September 26, 2017 at 9:14 pm
    I’ve only ever used expressions at a basic level but after messing with it a bit it seems that variables don’t maintain their values from frame to frame so perhaps even setting a param up to continually increment or decrement (without keyframes) is not currently possible with expressions – so the answer to my earlier question is probably “no.”
    I wouldn’t be disappointed to find out I’m somehow wrong about that though : )
    I was halfway thinking I had done this before but now I think I am misremembering it and what I was thinking of is a parameter behavior in Apple Motion called “Rate” which allows for doing this
  • Dan Ebberts
    September 26, 2017 at 9:22 pm
    This may be helpful:
    https://motionscript.com/articles/speed-control.html
    If you’re not discouraged after reading it, come back. ☺
    Dan
  • Dirk De jong
    September 26, 2017 at 11:36 pm
    [Dan Ebberts] “This may be helpful:
    Very helpful indeed – thanks a lot. For my relatively simple case (of wanting the Noise evolution to progress in a linear way without keyframes with some control over how fast it progresses) simply taking the first expression on the page you referred me to
    spd = 360;
    value + time*spd
    and in the place where the 360 is changing it to point toward my expression control
    spd = (thisComp.layer(“Null 1”).effect(“Slider Control”)(1));
    value + time*spd
    basically gives me what I was after – reading the article further and playing around with key framing the speed I see that it gets a little more complicated – but I can definitely work with this – thanks again
