Activity › Forums › VEGAS Pro › Interpolate, Blend or None? – Gaming Videos
  • Interpolate, Blend or None? – Gaming Videos
    Posted by Ken Layer on May 24, 2015 at 6:44 pm
    Hello Everyone,
    I use Sony Vegas Platinum 12 to edit my gaming videos for youtube.
    I record and render in 720p 60fps using SONY AVC mp4 format @ a bit rate of 20,000,000.
    From what I have seen based upon other youtubers settings, I have noticed that some change the fields in their property settings, for instance AntVenom uses None, while another video Ive seen using interpolate, while I am using blend fields.
    So basically, what are these fields, and is one better than the other for my main use of gaming videos?
    Thanks as always,
    -Ken
    Wayne Waag replied 11 years, 4 months ago 2 Members · 3 Replies
  • Wayne Waag
    May 25, 2015 at 12:26 am
    So long as you’re recording progressive video, which I presume you are, it really doesn’t matter. It is of importance only if your source is interlaced and you are rendering to a progressive format. In that case, you need to choose which de-interlacing algorithm Vegas uses–either blend fields or interpolate fields.
    wwaag
  • Ken Layer
    May 25, 2015 at 12:41 am
    Okay, thanks for the response. I ended up rendering all 3 types out and didn’t notice anything different. But I am glad I learned a little bit more about and when they should be used.
    Thanks for the help!
    -Ken
  • Wayne Waag
    May 25, 2015 at 12:54 am
    So long as your source is progressive, Vegas ignores this setting, so your three renders should be identical. Glad to be of help.
    wwaag
