Activity Forums Adobe After Effects Expressions interpolate between 2 keyframes
  • interpolate between 2 keyframes
    Posted by Jonas Espinoza on August 13, 2010 at 12:28 am
    i am trying to make a hundred or so assets push back in Z space, and each land on their own custom x,y ultimately at z= 0.
    i want to be able to globally change how long it takes all of them to make the move from custom keyframe 1 to custom keyframe 2, with a comp wide global variable for the langth of this move.
    is there a key.1 type of data for the position of the first keyframe? and is there a way to ramp from key.1 to key.2 over slider.duration length of time?
    im just trying to avoid moving all the keyframes to retime everything
    Jonas Espinoza replied 16 years, 1 month ago 2 Members · 3 Replies
  • Jonas Espinoza
    August 13, 2010 at 12:31 am
    hold on, i will post with better questions. finding some good stuff in the manual
  • Dan Ebberts
    August 13, 2010 at 1:54 am
    I think you might be looking for something like this:
    value1 = [100,100,500];
    value2 = [100,100,0];
    if (numKeys > 1){
    linear(time,key(1).time,key(2).time,value1,value2)
    }else{
    value
    Dan
  • Jonas Espinoza
    August 13, 2010 at 6:23 pm
    hey thanks
    yeah thats kinda what i have
    i am wondering how now i can add a random to an array value. in this case “p1” – i know how to generate a random value, but whats the procedure to add randomization to x and y of the 0,1,2 array and how would i add that to p1, which seems like it contains those 3 values inside of it
    i am trying to paste the code into the code box, let me know if you cant see it
    seedRandom(index+1, true);
    r = random()*4;
    p1=position.key(1).value;
    p2= position.key(2).value;
    duration= thisComp.layer("EXPRESSION CONTROLLER").effect("duration")("Slider")+r;
    ease(time, inPoint, duration, p1, p2);
