Activity › Forums › Telestream › Internet speed Vs window size
  • Internet speed Vs window size
    Posted by Anthony Faulkner on December 12, 2009 at 6:17 am
    Hi there,
    I am looking into getting a live stream set up. doing a one camera shoot through a lap top running wireacst. What are my minimum up and down speeds for viewing the different window dimensions? Is there anywhere where I can see a comparative list? Before I submit my proposal I’d like to know what is possible.
    ideally id like to use one of these. Am i dreaming?
    1280x 720
    or
    1920×1090
    Assuming I have the video streaming to certain locations with a garaunteed line speed, Is it possible to simultaneously send out another stream of a smaller size to a general home user audience?
    Or would i be better to record the stream and delay the presentation till after the heavier stream has completed?
    Thanks for any input
    Anthony Faulkner
    Anthony Faulkner replied 16 years, 9 months ago 3 Members · 3 Replies
  • Genevieve Lambert
    December 16, 2009 at 10:58 pm
    Hi Anthony,
    Streaming at those resolutions – 720p HD (1280×720) or 1080p Full HD (1920×1080) you will generally need an upload connection of 2.5Mbps-4Mbps to produce an end result that looks good. Your viewers will need 1.5 times that speed to ensure smooth playback.
    So – It is possible, but challenging.
    You can definitely use Multi-Bitrate streaming to supply a low/high quality stream based on the end-user’s connection speed. I believe the feature is available in WireCast.
    Daniel Yuna
    NetroMedia
    Streaming Provider & Host
    https://www.netromedia.com/
  • Craig Seeman
    December 16, 2009 at 11:48 pm
    720 might be passable at 1.5mbps but Daniel is correct.
    Wirecast can send multiple streams but make sure you have the upstream bandwidth to do that.
  • Anthony Faulkner
    December 18, 2009 at 2:11 am
    Thank you for your input.
