  • Crystelle Dalla betta
    November 24, 2009 at 2:27 am
    Another issue which is in IE6, which I wasn’t going to support, but is also an issue in AOL, is the menu. the div’s don’t quite line up. and I have no clue why. To see the site as it should look, look at it in firefox. everything appears to work fine there.
  • Fernando Mol
    November 24, 2009 at 2:49 am
    I suppose you could simply delete the lines of code that are showing in your page. They’re just empty comments.
    *Always share a link to your site and rate the posts. This is a free service for you and for us.
  • Mike Smith
    November 24, 2009 at 10:55 am
    IE 6 uses a different box model if the site is w3c compliant (standards mode) or not (quirks mode).
    Your site is probably triggering quirks mode by failing on standards ( https://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.dimartinoice.com%2F ) , though fixing this may or may not make the issue go away.
    https://en.wikipedia.org/wiki/Internet_Explorer_box_model_bug
    https://css-tricks.com/ie-css-bugs-thatll-get-you-every-time/
    November 25, 2009 at 3:05 am
    interesting. that would theoretically make perfect sense but when I delete the if and end if’s it screws up the entire layout.
    i’m just not going to worry about IE. looks fine in 8 as far as i’ve been told and browser shots shows me.
