Activity › Forums › VEGAS Pro › Internet 720
  • Internet 720
    Posted by Thayalan Paramasawam on September 1, 2015 at 12:49 am
    i render my project for youtube using mainconcept AVC/ACC.After i render….my file size is to large (1.9gb) and its take a hours to upload.How reduce my file size with good quality.
    Details
    Footage – 29 minutes long
    Project Setting – 1920X1080 50p
    Render Setting – Internet 720 (default Setting – i never change any setting)
    Pls help me on this matter…very urgent
    Thank You
    http://www.jptsskyvision.com
    System Details:
    Motherboard – Asus M5A99X-EVO,HardDrive1 boot C:SSD Kingston,Processor – Amd FX 8350 4.0/4.2 GHZ,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12
    Thayalan Paramasawam replied 11 years ago 4 Members · 15 Replies
  • 15 Replies
  • Steve Rhoden
    September 1, 2015 at 1:37 am
    No, use the Sony AVC Internet 720p template instead.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • John Rofrano
    September 1, 2015 at 5:14 pm
    [Thayalan Paramasawam] “After i render….my file size is to large (1.9gb) and its take a hours to upload.How reduce my file size with good quality.”
    File size is controlled 100% by bit rate. Lower the bit rate and the file will get smaller. Use the Two Pass option of MainConcept AVC if you need more quality at lower bit rates.
    [Thayalan Paramasawam] “Render Setting – Internet 720 (default Setting – i never change any setting)”
    The Sony template uses a very high bit rate. Probably higher than you need. I use 3Mbps – 4Mbps for my Boris TV tutorials and they look fine.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Thayalan Paramasawam
    September 1, 2015 at 10:46 pm
    Hi Sir (Mr.John Rofrano)
    Mr.John (I use 3Mbps – 4Mbps).Pls check my setting.
    Thank You
    System Details:
  • John Rofrano
    September 2, 2015 at 12:21 am
    [Thayalan Paramasawam] “(I use 3Mbps – 4Mbps).Pls check my setting.”
    That’s not the MainConcept AVC encoder. That’s Sony AVC. You did set it correctly for 4Mbps but MainConcept AVC will give you better quality at lower bit rates, especially if you use Two Pass (Sony AVC doesn’t support this).
    ~jr
    September 2, 2015 at 12:31 am
    Mr.John Rofrano(AVC will give you better quality at lower bit rates, especially if you use Two Pass (Sony AVC doesn’t support this).
    1)Sir can you screen shoot me how to set.
    Thank you
    System Details:
    September 2, 2015 at 12:38 am
    Mr.John Rofrano(Boris TV tutorials and they look fine)
    Sir pls send me link,now i start to using boris so i need tutorials.
    Thank you
    System Details:
  • John Rofrano
    September 2, 2015 at 12:52 am
    [Thayalan Paramasawam] “can you screen shoot me how to set.”
    Then set the Average (bps): to 4,000,000.
    ~jr
    September 2, 2015 at 12:55 am
    MR.John Rofrano…How about maximum (bps)
    System Details:
  • Danny Hays
    September 2, 2015 at 4:16 am
    September 2, 2015 at 4:26 am
    Thanks Mr.Danny Hays
    System Details:
