Activity Forums Apple Final Cut Pro Legacy Internal trim
  • Posted by Jesse Adlin on October 1, 2009 at 4:08 pm
    Hi-
    Making a transition from Avid to FCP. Easy question that I can’t find an answer to… probably b/c terminology is a bit different from one app to the next.
    I have a video clip sandwiched by two other clips. I want to change the start and end of the clip in the middle without affecting the other clips. I would call this an internal shift or internal trim.
    What does FCP call this and how can you execute.
    Thanks.
    Jesse Adlin replied 16 years, 11 months ago 3 Members · 3 Replies
  • Stephen Smith
    October 1, 2009 at 6:42 pm
    You want to take a look at the Ripple Tool. It lets you adjusts a clip’s In or Out point, making the clip longer or shorter, without leaving a gap in the Timeline. Its should be on page 700 of your manual. It effects either clip on the In or Out depending on what side of the cut you use the tool on. Hit the R key twice to get the tool. Hope this helps.
    Utah Video Productions
    Check out the Graphics Demo Reel I did.
    Check out my Motion Tutorials
  • Dennis Leppell
    October 1, 2009 at 8:14 pm
    another useful tool, in the same vein, is the slip tool. it will slide the in and outs of the clip simultaneously, while maintaining the clip’s length and not affecting the clips around it.
  • Jesse Adlin
    October 2, 2009 at 4:41 pm
    Thanks. The slip tool is what i was looking for.
