Activity › Forums › Adobe Encore DVD › internal software errors
Jeff Bellune
August 10, 2006 at 4:10 amGuy,
I know you have real work to do, but if you get a chance in the next couple of days could you please test something for me?
Regardless of the underlying cause for the CTimeMapBuilder error, or the number of chapters in the timeline and Chapter Playlist, I think I have found a universal workaround:
1. Place your first chapter marker and then your last chapter marker.
2. Set the end action for your first chapter.
3. Create a new Chapter Playlist.
4. Add both chapters to the Chapter Playlist.
5. Do a Preview From Here for the new Chapter Playlist.If the CTimeMapBuilder error appears, don
Jeff Bellune
August 10, 2006 at 12:36 pmRE: my previous post – Obviously, the first chapter marker is automatically created, so the first chapter marker to be added manually in this procedure is the last chapter.
Sorry about that
Jeff Bellune
August 10, 2006 at 9:32 pmThanks for checking this out. I had high hopes since it worked for me in 3 different test projects where I was able to induce the error.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Guy Kingston
August 10, 2006 at 10:07 pmI’ll try to have another go in a few days with a fresh approach. I’m feeling rather tired today so I might have overlooked something.
In the meantime thanks also for the advice on working around a lack of FF in Preview.
Guy.
The Mind Your Own Business Podcast – the Business Owners’ podcast – http://www.myobpod.com
