Activity Forums Adobe Encore DVD internal software error
  • internal software error
    Posted by Guy Kingston on July 30, 2006 at 7:43 pm
    I’m having some problems with internal software errors when I try to Preview my project.
    Having looked at other posts I have made sure I have no overrides in my project but if anything this makes the problem worse.
    With the main timeline End Action set to Return to Last Menu and Override set to a specific menu:
    internal software error: .\EditorTemplates.cpp, line 698
    With main timeline end action set to return to last menu and override not set:
    internal software error:.\Navulator\CTimeMapBuilder.cpp, line 71
    Then when I click on OK I get this error message:
    internal software error:.\Plans\TitlePlan\VIDEOTSLayout.cpp, line 828
    which typically repeats about 6 or 7 times.
    The same thing happens with the main timeline end action not set and override not set.
    Check Project reports no errors.
    My project consist of one long avi file, and the whole thing will (just) squeeze onto a single 4.7GB DVD after transcoding when the project is built.
    I have set four chapters and have a single menu with a Play All button plus separate buttons for each of the chapters. These separate buttons are linked to the Chapter Playlist while the Play All button is linked to the main timeline. There is no End Action set for the last chapter.
    Any suggestions/ideas?
    Many thyanks.
    Jeff Bellune replied 20 years, 1 month ago 2 Members · 1 Reply
