Activity › Forums › Apple Final Cut Pro Legacy › Internal RAID
Internal RAID
Posted by Philip Lucero on February 10, 2009 at 8:13 pmI have a MacPro Quad Core Intel with 5GB ram and three 500GB internal SATA drives in a RAID array. Is it possible to remove those drives and place them into an external RAID enclosure (eSATA) without reformatting the discs. I want to replace them with three 1.5TB drives.
Thanks in advance.
PhilSean Oneil replied 17 years, 6 months ago 5 Members · 12 Replies -
Ernie Santella
February 10, 2009 at 8:47 pmYes, I’ve done the exact same thing. I took my 3 internal raid drives and installed them in a Sonnet Raid enclosure. Worked fine.
Ernie Santella
Santella Productions Inc.
http://www.santellaproductions.com -
Ben Holmes
February 10, 2009 at 11:07 pmYou can remove and replace multiple sets of RAIDed drives with no problems – I’ve frequently swapped 3 drive internal arrays between systems. Very useful…
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer -
Elijah Lynn
February 11, 2009 at 1:10 amBen, have you swapped them between manufacturers too? I need to swap out a Apple Raid card to a Caldigit card and didn’t even think that was possible, at least Caldigit said it shouldn’t be.
Sean Oneil
February 11, 2009 at 3:04 am[Philip Lucero] “I have a MacPro Quad Core Intel with 5GB ram and three 500GB internal SATA drives in a RAID array. Is it possible to remove those drives and place them into an external RAID enclosure (eSATA) without reformatting the discs. I want to replace them with three 1.5TB drives.”
Yes.
Sean
Sean Oneil
February 11, 2009 at 3:05 am[Elijah Lynn] “Ben, have you swapped them between manufacturers too? I need to swap out a Apple Raid card to a Caldigit card and didn’t even think that was possible, at least Caldigit said it shouldn’t be.”
You can’t change hardware-RAID cards (CalDigit, ATTO, etc.) but with software RAID (Disk Utility) you can. A RAID created with Apple RAID card might work in software mode as well, not sure.
Sean
Elijah Lynn
February 11, 2009 at 3:10 amWhat was your initial internal raid built on? Disk Utility or a Hardware raid and which MFG?
Ben Holmes
February 11, 2009 at 9:55 amAbsolutely correct – I am talking about RAID 0 internal arrays created with disk utility – sorry if that wasn’t clear.
Just think it’s a useful and little known benefit of software RAIDS. I’ve never used the Apple RAID card, I hear about endless problems with them. I’d prefer to use an external array, so they can be swapped as required.
Ben
Edit Out Ltd
Elijah Lynn
February 11, 2009 at 6:50 pmSo if you created a software raid with Apple DIsk Utility and then swapped the array with no problems to a 3rd party mfg hardware raid?
That is pretty interesting!
Ben Holmes
February 11, 2009 at 9:17 pmNo – I said I had swapped sets of drives in an internal array, not into an external array. I would think that would be impossible, as generally the external array contain their own RAID hardware, or are larger SCSI/FC systems requiring PCI RAID cards in the Mac.
Edit Out Ltd
Ernie Santella
February 11, 2009 at 9:19 pmI’ve swapped my internal 3 raid drives into an external Sonnet drive enclosure with no problems. They came up fine.
Ernie Santella
