Activity Forums Apple Final Cut Pro Legacy internal or external RAID 0
  • internal or external RAID 0
    Posted by Gyorgy Beck on August 3, 2010 at 7:38 pm
    Greetings for you all. This is my first post here and the question I’m about to ask seems very simple, but after a lot of google-ing I’ve found the answers quite contradicting. I’m about to start a new project which is a multi-stream video installation using several different kinds of source material. I want to optimize my Mac Pro and FCP for the job. I’ve bought two 1TB hard disks for RAID 0 and a 2TB for Time Machine backup. Since I already have four disks in the computer, I was thinking about taking two disks out and put them in a FW800 external enclosure, and put the two new ones in, for the RAID 0. Then I thought it might not be necessary and I should just create the RAID in the FW800. I google-d a lot to find out the advantages and disadvantages of having internal or external RAID 0, but I could not reach a solid conclusion. I’ve got more and more curious, so I’ve thought I’ll ask your opinions. Thanks.
    http://www.silencefriction.net
    Rob Rippe replied 16 years, 1 month ago 4 Members · 4 Replies
  • Jason Brown
    August 3, 2010 at 8:27 pm
    I’m running internal 3 drive raid 0. 4th drive is system drive. I Have external lacie as time machine backup. IMO I don’t see a need to waste internal bay on time machine…it could be connected USB for all purposes and run overnight.
  • Jeremy Doyle
    August 3, 2010 at 8:31 pm
    I’m not sure of all the advantages or disadvantages are, but the big advantage I do see is, if you go internal you’ll be running on a SATA interface so your RAID 0 will be much faster than if you configure it via firewire. And if you’re running RAID 0 I’m assuming you’re going for speed especially if you’ll be backing up to a 2TB drive.
  • Gyorgy Beck
    August 3, 2010 at 9:56 pm
    Thanks for the answers.
    Jason, I might have not been clear in the post, but I did plan to have the backup external and I’m only unsure whether to go internal with the RAID.
    Jeremy, I also thought the speed could be the issue, but some people claim that using FW800 the speed difference is minimal if any, If the deadline would not be so close I would do a thorough test to see the digits. 🙂
  • Rob Rippe
    August 4, 2010 at 1:41 am
    I would agree w/ Jeremy. I have 3 500gb internal hard drives on a 0 raid.
    Using blackmagic’s disk speed test, I have Read @ 222.9 MB/s and Write @ 225.8 MB/s.
    My external (each on an independent computer lead) 800 firewire drives are slower.
    Note: if you have multiple drives connected to one firewire cable going to your computer (a daisy chain of drives), speed will default to the slowest drive.
