  • Posted by Jakob Wagner on December 12, 2018 at 3:42 pm
    Hi
    I want to have a JSON object, but not in a seperate file. Instead I want to put the JSON object on a text layers sourcedata. And then have other layers get the values from that layer. I can’t seem to figure out a way to do this.
    In the test I have two text layers. In the first (called data) layers sourceText I have the following expression:
    ‘{“blur”:{“bluriness”:0}}’;
    In the second text layers sourceText I have this expression:
    var data = eval(thisComp.layer(“data”).text.sourceText);
    data.blur.bluriness;
    This is not working. Do you have any idea what could make it work?
    Jakob
    Jakob Wagner replied 7 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 12, 2018 at 5:37 pm
    Try it this way:
    var data = eval( “(” + thisComp.layer(“data”).text.sourceText + “)”);
    Dan
  • Jakob Wagner
    December 13, 2018 at 9:12 pm
    COOL! That works. Thanks.
