Activity Forums Storage & Archiving internal hard drive readers/enclosures…?
  • internal hard drive readers/enclosures…?
    Posted by Grant Wilber on October 19, 2012 at 2:26 am
    I’ve been using internal hard drives and popping them into a voyager drive mount. Really like doing this as I can slowly build up my storage and its pretty cheap.
    One thing I don’t like is that if you have multiple drive mounts daisy chained, and you eject a drive it kills the connection flow. A normal hard drive you can shut it off but the connection still remains.
    Does anyone know of mounts that I can eject hard drives out and it won’t disrupt my daisychain flow? Or are there any good enclosure systems where I can just pop in hard drives in and out easily?
    Tim Jones replied 13 years, 10 months ago 2 Members · 1 Reply
  • Tim Jones
    October 31, 2012 at 5:13 pm
    That’s the problem with disk drives in this scenario – the default OS drivers expect them to be single entities, so if you pop a drive, it’s no longer available so the OS drops it.
    One solution (assuming your editing software can handle it) is to create a folder in your user folder and then place symlinks (not Aliases) via the Terminal in that folder that point to your volumes. For instance:
    Your physical disks are named:
    Shots Drive A
    Shots Drive B
    Shots Drive F
    In your user’s folder, create a folder named “Drive Links”
    Open the Terminal and cd into that folder
    cd ~/Drive\ Links
    Mount your drives in sequence
    Create the symlinks
    sudo ln -s /Volumes/Shots\ Drive\ A ./Shots\ Drive\ A
    (repeat for each drive as you mount it changing A to B, C, you get the pattern) )
    As you mount each volume, it’s symlink will become a valid target, but when you eject each drive, the symlink remains and yourapplictions won’t get a notice that the drive has gone offline.
    I can’t promise that this will work for all applications, but it does for Smoke 13, After Effects, and Premiere Pro (it doesn’t for FCP X because of their dependence on physical drives) and it works for most other “general” apps.
    HTH,
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
