Activity Forums Apple OS X Internal Drive Space
  • Internal Drive Space
    Posted by Stef Allan on March 9, 2011 at 9:47 pm
    Hello,
    I’m sorry if this is a redundant post but I did a couple searches and couldn’t quite find an equivalent question. Here’s my issue:
    I was lazy and put a ton of RAW image files, video clips, and music on my MacBook Pro’s internal drive (500GB drive). The drive got to be over 90% full (less than 20GB available). I know this is a no-no on a startup drive. What I’ve heard is that there is something to do with where the computer stores the data as it gets more and more full. I have now moved a lot of the data to external drives and the drive is only a little more than 70% full. I’m still working to eliminate as much other stuff from the internal drive as possible. I’ve heard 50% full is good.
    Anyway: if the actual location on the computer is the important thing about performance issues when the startup drive is full, is there a utility that I can use to rearrange the data on my drive?
    Is this defragmenting? I know I did that on an old Dell laptop I used years back.
    Will I be okay now that I’ve just moved a bunch of the media to externals?
    Stef
    Stef Allan replied 15 years, 6 months ago 2 Members · 2 Replies
  • Jerry Jorgenson
    March 10, 2011 at 1:24 pm
    – What I’ve heard is that there is something to do with where the computer stores the data
    Unix systems guarantee that the first write will be in a contiguous area. If you don’t have enough free space the filesystem will either have to move files around or (worse) give a filesystem full error. Generally as long as there is 15% free it’s not going to be a problem.
    – is there a utility that I can use to rearrange the data on my drive?
    There are several:
    Finder (GUI)
    tar (command line)
    mv (command line)
    – Is this defragmenting?
    No. Defragmenting is different. There are utilities that can defragment a Mac, but they seldom need to be used because of the way Unix filesystems operate.
    – Will I be okay now that I’ve just moved a bunch of the media to externals?
    Yes.
  • Stef Allan
    March 10, 2011 at 4:06 pm
    Thank you,
    Stef
