Intermittent noise on TOA wireless mic system
Posted by Mick Wall on October 19, 2020 at 5:36 pmHi folks, I am having an issue with a sound installation in my church. We are having an issue where we hear a very loud noise intermittently.
The setup is 4 wireless Toa UHF receivers, these are installed in a rack, we have two aerials installed for the dual diversity system.
If we have the receivers on and the wireless “packs” off we don’t have an issue, however when we turn on any of the packs we will get this noise.
In the video I have added you can see it happening on the two mics that I have switched on at the time. It doesn’t matter if I only have one on we still get the issue,
I am hoping that some of you may have heard this noise before and can point us in thr right direction to fix it,
The video is here
https://www.stjohnsshirley.org.uk/wp-content/uploads/2020/10/Sound-Issue.mp4
Many thanks
Mick
Ty Ford replied 5 years, 11 months ago 4 Members · 10 Replies -
Blaise Douros
October 19, 2020 at 7:52 pmThe first thing I would check would be that there’s no RF interference–most receivers have the ability to scan for clean frequencies, and then set the transmitters to match. Also, I note that it’s happening on two channels, so it might be worth checking to make sure that those two mics aren’t set to the same or similar channels, thus interfering with each other.
How about the batteries in the mic packs? Are they nice and charged? Sometimes weird things happen on a struggling low battery.
Mick Wall
October 19, 2020 at 7:58 pmCheers
New batteries in both packs, these are on channel 70 on these frequencies
Ch C 863.125 deregulated
Ch D 863.375 deregulated
Ch E 864.125 deregulated
Ch F 864.375 deregulated
Mark Suszko
October 19, 2020 at 8:23 pmSounds like a squelch? Are these mics gated at all? Do they have some kind of auto-level-control applied to them? Also, because I’m just grasping at straws, is the power supply to the receivers clean and isolated, or are these power spikes getting thru? How irregular are they?
Mick Wall
October 19, 2020 at 8:43 pmNo level controls, power supply is pretty clean. The installation has been fine for quite some time but now we get this noise. I would say quite regular, 1 to 2 every few minutes
Blaise Douros
October 19, 2020 at 10:50 pmI think the first thing to look at is whether there is some faulty electrical equipment you can link to the noise. So turn off the fluorescent lights, for example–if the noise goes away, start looking for the bad fixture.
Does this ONLY happen when there are multiple mics turned on? If so, then it’s possible they’re interfering with each other–that being the case, you can start switching channels around. How close are the receivers to each other? Sometimes receivers that are stacked closely together can also cause problems.
Anyone get a new cell phone recently? This doesn’t sound like GSM noise, but it’s always possible.
Blaise Douros
October 19, 2020 at 11:03 pmOne last thing–I found something suggesting that cell phone 4G signals sit just below the low end of channel 70, near the 863 range. https://www.soundservices.co.uk/wireless-microphones-radiomics-uk/ So maybe pushing the channel settings up to the top of the available settings, to the 865 range if possible, might help, too.
Listen to the noises produced here: https://www.apwpt.org/technical-papers/dr-h-b-karcher/lte-interference-to-wireless-headphones/index.php sounds like longer versions of what you posted, no?
Mick Wall
October 20, 2020 at 3:08 pmThanks, I think it maybe the 4G issue, we have a transmitter not too far away.
I am going to try and get the radios hopefully retuned, if not I feel we may have to replace them and get some we can “licence”
Ty Ford
October 21, 2020 at 1:45 pmHi Mick and thanks for reaching out. Thanks also to everyone who responded. It’s been a bit quiet here. I appreciate your thoughtfulness and effort.
I’ll add another weird possibility. The video you provided — and thanks for that! — reminded me of a situation in Boston some years back after the install of a new DAW. In that case, the timing was very cyclical; like every 10 seconds or so. It was eventually found that the new studio’s location on the third floor of the house, put it in the way of a Boston Airport radar tower some miles away that was sweeping for air traffic.Regards,
Ty FordCow Audio Forum Leader
Blaise Douros
October 21, 2020 at 4:21 pmWeird possibilities abound in this business. When I was working for a small studio in Monterey, California, we kept getting this weird staticky interference on our powered studio monitors in one of our edit suites. I checked EVERYTHING. Power grounding, loose connections between audio interface, ferrite on the computer’s power cables, sound card, different output channels on the mixer, different sources, but it was always intermittent and I could never trace it. Then one day, the static resolved into the local radio station–the cables were coiled in such a way that they were acting as a perfect antenna, and the powered monitors were amplifying the signal. I switched to shielded cables.
Ty Ford
October 21, 2020 at 4:55 pmIf local RF is turns out to be the issue, using the Neutrik EMF suppression XLR connectors has worked here for blocking client iPhone induced RF into a mic cable.
https://bhpho.to/3o7an5k
Maybe try a pair on one cable….
Oh! and another anecdote! Peabody Conservatory’s BIG transformerless input console, a Sony I think, was having problems. Preamps were blowing out. It was found that the very long mic lines leading to the console from the concert hall were long enough to pick up stray voltages. They solved the problem by putting transformers in front of the mic inputs on the long lines.
