Activity Forums Adobe After Effects intermediate result colors change in final result
  • intermediate result colors change in final result
    Posted by marc maze on September 27, 2021 at 12:39 pm
    ave several comps… each is an MP3 audio linked to an MP4 video… 1st 2 I keyed no issues… this one has drummer in blue jeans and a blue shirt… key settings…screen gain..105, balance …50, clip black 10, clip white..55, screen shrink … -1, chatter on…
    When use Standard spill suppression, green spill is gone, intermediate show correct color of blues, everything looks great…when switch to Final.. all blues change to green
    When use Ultra spill, colors are correct, but get no spill suppression… haven’t changed any default Ultra setting, when use Ultra dropper on a green area… nothing happens
    transparency is on behind subject… export quicktime, res4444 with AE, .mov is green, not original blue
    Intermediate looks perfect, final result, not so, black drum attachments are blurry also
    Thanks.
    Very Confused
    Images:
    Original screen, screen matte, Interm results chatter. Interm results spill supp, Final results chatter, Final results spill supp
    marc maze replied 4 years, 10 months ago 3 Members · 5 Replies
  • Andy Kiernan
    September 29, 2021 at 3:48 pm
    not sure this would help, but I usually just key to make a b/w matte then precomp and use that to matte out the original footage and colour correct that/ refine matte etc etc. Sorry if this is no help
  • marc maze
    October 1, 2021 at 1:49 am
    Thanks for response… not sure what you mean “precomp”…
    The other thing that is unusual, if I change the green spill key from “standard” to “ultra”, then it clears out spill and doesn’t effect color from intermediate to final….
    I have exported a keyed clip with alpha channels in various formats using the standard spill and noting the color changes as shown, and the results show that the colors are exported with the original colors altered.
    Still trying to get explanations..
  • Andy Kiernan
    October 1, 2021 at 7:52 am
    what I meant was pre-compose the keyed footage (keylight set to matte, so you see a black and white image) then use that pre-comp as a matte over the original clip. Also when using just keylight, I think its best to use ‘intermediate’ (then use spill suppressor and key cleaner), as ‘final’ uses its own spill suppression features which may be whats altering your colours
  • Kevin Camp
    October 1, 2021 at 9:48 pm
    Keylight has spill suppression built in.
    My guess is that when you look at it in intermediate, that spill suppression is disabled in the preview.
    Then you’re adding another effect to do the spill suppression while keylight is not suppressing the spill (in intermediate), and you have things looking good with that other suppression effect.
    Then when you switch to Final Result, Keylight is doing the spill suppression and changing the colors of the footage and that causes the other spill effect to get confused and that messes things up.
    I’d either keep Keylight in intermediate (thus disabling it’s built in suppression) or remove the other spill suppressor. It would seem too many spill suppressors is not a good combination.
  • marc maze
    October 6, 2021 at 7:15 pm
    Just curious why when set on Ultra rather than standard… spill suppression doesn’t change original colors
    thanks
