Activity Forums Blackmagic Design Interleaved files.
  • Interleaved files.
    Posted by Paul Spurrier on October 30, 2005 at 10:24 am
    I have a Premiere Pro timeline that is 105 minutes long.
    It comprises a single Quick Time Movie file using the Black Magic 10 bit codec, plus a synced WAV file – stereo 48k 16-bit.
    When I tried to play the timeline out in Premeiere Pro, it went noticeable out of sync after about 30 minutes.
    On the timeline it is most definitely in sync, so the drift only occurs in playback.
    I then had the bright idea of rendering an interleaved file. I thought that if the video and audio were interleaved, they couldn’t possibly drift out of sync.
    This turned out to be a disaster.
    For some reason that I don’t understand, Premiere insists on conforming every audio clip it loads into 32-bit floating point. Unlike old versions, you cannot set the project settings to a particular bit-depth – sample rate, etc.
    (I think this is a very odd quirk of Premiere).
    And upon import of this 105 minute interleaved file, Premiere sat ‘conforming’ for about six hours (the blue bar did move up very slowly) it then crashed.
    I am a bit stuck.
    I am producing the Black Magic files in Combustion and need to be able to output them.
    I have tried using Vegas but have had zero success – maybe because of the interleaving again.
    Has anyone had a similar problem with Premiere Pro.
    Paul
    Sameer Shrivastava replied 20 years, 10 months ago 3 Members · 2 Replies
  • Luke Maslen
    October 31, 2005 at 1:23 pm
    Hi Paul,
    Please review the support note Video increasingly lags behind audio in Premiere Pro and let me know if this helps or explains your problem.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Sameer Shrivastava
    October 31, 2005 at 8:31 pm
    Which ver. of blackmagic drivers are you using. Please check my experiances and temp. solutions on my post “Audio sync problems” Dtd 30 th sept. i had the same problem but my time line was much more complicated but audio was one clip. First i thought my raid may be the problem but just two days back somebody reported the same problem with 1.8 tb raid. i guess that must be a very fast raid. please share your raid details.
    thanks
    sameer shrivastava
