Interlacing Woes- CS3
Working on a video for our wedding. Just recently purchased a Sony HDR-HC9 miniDV high definition movie camera so that I can best work with footage in Premiere Pro CS3 without having AVCHD issues. This post is wordy but it’s an attempt to get across as much detailed information as I can.
The question at the end of all this is, how can I get best results for playback on my computer to be played through a VGA cable projector at our reception?
I’m working on a laptop that is not enabled for what Sony calls ‘Full HD’ or simply 1080p display.
I am no expert with settings for video but I’ve been lurking around and Googling enough to know basic terms and to dabble with settings. That said I chose the following at setup, stop me if I took a wrong step somewhere.
Editing Mode: HDV1080p
29.97fps
Pixel Aspect Ratio: HD Anamorphic 1080
Fields: No Fields Progressive Scan
Display Format:30fps Drop-Frame TimecodeThe preview footage looks smashing.
On advice from a friend from long ago whenever rendering I render as Microsoft AVI without any compressor. I then take that into Virtual Dub and compress it with Xvid. This could be totally wrong but it’s what I know. If anyone has any advice to this point I’m all ears.
Now, the ultimate playback looks horrific. I realize this is because my laptop monitor is not designed for 1080 display. However, I was a bit shocked when I plugged the laptop into my Full HD Bravia via a VGA cable and saw the same terrible quality in the final AVI.
I realize this has to do with interlacing and/or deinterlacing. From reading past threads I’ve gathered that in my case, deinterlacing would be a BAD thing. Understood. But what can I do to make this video look better?
Interestingly enough. I was working on a different but related project. I was doing some chroma key work where I imported footage from the camera into a project where the Editing Mode was DV not HDV. The HDR-HC9-shot footage looked remarkable. Really slick.
What gives?
In the end if this doesn’t work should I simply redo the project in a DV editing mode? Just a coincidence?
Thanks guys, you rock.
