Activity Forums Adobe Premiere Pro Interlacing Problem
  • Interlacing Problem
    Posted by Mike Hoffman on November 6, 2010 at 7:12 pm
    I used After Effects to convert a 25 fps progressive clip to NTSC widescreen. The resulting clip is what you would expect: 720×480, 29.97 fps, interlaced (bottom field first). The new clip looks exactly how I want it when I play it with media players and also when I view it on the timeline in Premiere CS4. However, when I go to export Media Encoder now shows the source with that bad interlaced look like this:
    https://www.windowsmoviemakers.net/PapaJohn/54/Interlaced-Versus-Progressive_files/image001.jpg
    Anyone know why?
    P.S.: When I deinterlace for the web it looks good but I want to put it on a DVD too.
    Ann Bens replied 15 years, 10 months ago 3 Members · 5 Replies
  • Ann Bens
    November 6, 2010 at 8:47 pm
    Just put the footage on a dvd.
    Dvd players can handle interlaced footage just fine.
  • Vince Becquiot
    November 6, 2010 at 9:05 pm
    As Ann Said, this will no show up on a TV played when in a DVD player.
    If this is exclusively going to be played on computers, you can de-interlace, but you will lose some resolution in the process.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Mike Hoffman
    November 6, 2010 at 9:29 pm
    Hmmm, I’m putting together a bunch of different videos on a DVD and so far none of the other resulting m2v files that Premiere exported (using the same DVD MPEG-2 preset) look that way when I play them on my computer. I can’t figure out why this one is different.
  • Vince Becquiot
    November 7, 2010 at 12:49 am
    It likely has to do with the particular motion in that clip. How is the resulting DVD?
    Vince Becquiot
    Kaptis Studios
  • Ann Bens
    November 7, 2010 at 5:38 pm
    Converting from pal to ntsc and then to mpeg is quite a long process.
