Activity Forums Apple Final Cut Pro Legacy Interlacing on 24p Sequences
  • Interlacing on 24p Sequences
    Posted by Is759@bard.edu on February 16, 2006 at 9:24 pm
    I captured 24p footage from a canon xl2 onto final cut pro HD. The settings were set for both the timeline and capture presets to 23.98 progressive. The clips play back indevidually with no problems but once they are edited into a sequence some strange interlacing occurs about once every 4 frames, which, on an ntsc monitor, translates to a jumping image. The clips do not need to render so I assume that the settings are the same between the capture presets and the timeline. But when I compare the same frame from the clip side by side with the clip integrated into the sequence, the interlacing only shows up in the sequence. Any suggestions?
    Ian
    John Pilgrim replied 20 years, 6 months ago 4 Members · 3 Replies
  • Kevin_edits
    February 16, 2006 at 10:07 pm
    First: when was the last time you trashed your preferences?
    I found a neat little app called Final Cut Pro Rescue (thank you COW)
    that saved my butt recently
    Second: Check for THIRD party setting conflicts IE: Cinewave / Aurora / AJA / BlackMagic
    Third: Create a new project and make sure the project has the settings you plan to use
    before you import the media. (timeline / scratch disk / etc. )
    FOUR: DON’T PANIC Perhaps this should have been first.
    Welcome to our Digital Dojo
  • Ben Insler
    February 16, 2006 at 11:15 pm
    Are you sure that you don’t have FCP set to insert a 24p pulldown on the fly so that you can view your sequence on an NTSC monitor (which is 60i)?
    Ben Insler
    Editor
    Telemark Films
  • John Pilgrim
    February 17, 2006 at 4:26 am
    With a regular NTSC monitor, FCP has to insert a pulldown to convert from the sequence’s 23.976 framerate to the monitor’s 29.97 framerate. You can choose which pulldown cadence in the System Settings/Playback Control tab, but you can’t avoid it unless you have a high end HD monitor that accepts native HD (720p / 1080i) or at least native 480/24p.
    John
