Activity › Forums › Apple Final Cut Pro Legacy › Interlacing observed on the Canvas but not the viewer
  • Interlacing observed on the Canvas but not the viewer
    Posted by Joshua Lim on January 13, 2006 at 8:48 am
    hi everyone,
    after reverse telecine, the interlaced frames are removed from the clip when viewed in cinema tools and in the viewer. However, when i put the clip onto the sequence (without rendering or needing to: the bar remains grey above the clip), interlaced frames are observed.
    for the same timecode/frame, the viewer has no interlacing but the canvas has.
    is this normal or is it indicative of some problem?
    in the end i would make a cut list for the negative cutter and it’s vital that the key codes are accurate.
    really appreciate any feedback!
    thanks!
    josh
    Joshua Lim replied 20 years, 8 months ago 3 Members · 3 Replies
  • Chris Poisson
    January 13, 2006 at 1:44 pm
    The canvas displays rougher video than the viewer, you need to see the work on an NTSC monitor.
    Have a wonderful day.
  • Malfunkt
    January 13, 2006 at 2:27 pm
    if you have ‘all frames’ selected, the viewer window will show both fields if there is interlacing, otherwise it just shows one field. the canvas asfar as i know will always show one field.
  • Joshua Lim
    January 15, 2006 at 8:24 am
    thanks for your responses!
    when i export the sequence full quality and view it on quicktime, the interlacing remains. this is the interlacing observed from the canvas but absent at the very same frame on the viewer.
    is it strange? is this indicative of a problem in the reverse telecine?
    appreciate any further input! thanks a billion.
    joshua lim
