Activity Forums Apple Final Cut Pro Legacy interlacing issue–please help — revision
  • interlacing issue–please help — revision
    Posted by Jaclynvt on January 20, 2006 at 8:25 pm
    I have footage from a 2 camera shoot. the cameras were beta SP.
    They were captured to Final Cut as Uncompressed 8-bit.
    The sequence settings match the clips.
    I exported the quicktime movie with the sequence settings.
    the file looks has a weird interlacing issue…When someone moves across the frame, there are obvious (interlace-looking) lines.
    There was an intro created by someone else (animation codec) which looks clean.
    Is this a Final Cut Studio interlace setting that I have overlooked when importing the orginal footage?
    Any ideas? Any help would be much appreciated.
    Brian Pitt replied 20 years, 7 months ago 2 Members · 1 Reply
  • Brian Pitt
    January 20, 2006 at 9:48 pm
    Have you tried watching the footage on an NTSC monitor? The problem you are describing commonly happens with LCD displays, even if the clip has no interlacing problems…
