Activity › Forums › Avid Media Composer › Interlacing issue of some kind maybe?
  • Interlacing issue of some kind maybe?
    Posted by Milton Hockman on October 24, 2006 at 2:15 am
    I don’t get this.
    I am capturing footage from a Sony XDCAM deck at DV 25 res in Xpress Pro.
    The footage is 16×9 native res.
    One clip contains an African American man moving in the frame on a white background.
    I put the clip into my timeline and add a Reformat Effect to fit it into a 4×3 space.
    Video Settings are at Full Quality.
    When i play the clip, i see an interlacing type of issue around the man’s chin. It looks like horrible stair stepping.
    I have no idea why this is. With other clips i get a similar problem. When i play it back i can tell something is not right….like it is flickering or something, and when i stare close it is the same thing, stair stepping type problem.
    Anyone know how to help me fix this? I feel like i have done nothing to get such bad quality.
    Grinner Hester replied 19 years, 11 months ago 2 Members · 3 Replies
  • Grinner Hester
    October 24, 2006 at 6:19 pm
    Ihave never had luck with any reformat effect. A resize effect may work better for you. 77% scale on the horizontal otta do ya better. I have noticed even the letter box is aliased with reformat.
  • Milton Hockman
    October 24, 2006 at 6:50 pm
    i just noticed that this same thing is occuring on a clip that has a BCC levels adjustment. for some reason even if i render the filter it stills causes a stair stepping, but if i take it off and render the clip it looks sharp.
    waht is up?
  • Grinner Hester
    October 26, 2006 at 5:37 am
    I use to think it was the card. Then 8 bit vs 10 bit. Now, it all points to their code.
    I had just grown use to keeping AE and photoshop open in all sessions because of this. Now that their apps are software-driven, ram gets all fussy. This, along with the new bugs results in Adrenaline being a major downgrade from the old meridien-based products.
    at least for me.
