Activity Forums Apple Final Cut Pro Legacy interlacing in FCP from Avid Same as source quicktimes
  • interlacing in FCP from Avid Same as source quicktimes
    Posted by John Reis on September 30, 2008 at 4:34 am
    G5 running 10.5.4 with FCP 6
    I exported some quicktimes Same As Source 1:! from a Symphony Nitris, and they appear interlaced in Final Cut.
    I thought I needed to update my avid codec and downloaded the Avid LE 1.9 package- still interlaced.
    Any ideas?
    Sean Oneil replied 17 years, 11 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    September 30, 2008 at 5:04 am
    Is it not supposed to be interlaced? What format?
  • Sean Oneil
    September 30, 2008 at 6:55 am
    In the FCP Browser you can manually set a clip to be upper field, lower field, or none. Set your to none before you place it on a timeline and it will no longer be interlaced.
    Sean
