Activity Forums VEGAS Pro interlacing flicker in vegas pro
  • interlacing flicker in vegas pro
    Posted by Troy Musson on August 10, 2011 at 7:52 am
    Hi guys
    I need a bit of help with vegas pro, I am reasonably new to video editing but ive grasped vegas pretty quick, my problem is i cannot seem to get rid of flicker in occassional clips. I am creating a wedding dvd which is 45mins long. the spec is PAL, 16.9 INTERLACED FROM MINI DV, vegas setup is lower field first main concept mpeg2 template 720 x 576 25fps ,interpolate fields, best,adjust source media unticked,dvd architect pal widescreen,Iframes 15, bit rate variable max 9 min 192,000. event reduce interlace flicker ticked and force resample.
    After about rendering 10 times with different formats I am now pulling my hair out , the last render took 20 hours and i still have this problem. I have to say that the flicker is not in all the edited clips but very evident never the less. Please help someone ,any suggestions? thank you.
    Troy
    Greg Frediani replied 9 years, 10 months ago 6 Members · 13 Replies
  • 13 Replies
  • Nigel O’neill
    August 10, 2011 at 2:52 pm
    Try this (changes in bold):
    The spec is PAL, 16.9 INTERLACED FROM MINI DV, vegas setup is lower field first main concept mpeg2 template 720 x 576 25fps ,blend fields, good,adjust source media ticked,dvd architect pal widescreen,Iframes 12, bit rate constant 8,000,000. event reduce interlace flicker unticked (should only be used for still images) and smart resample.
    These settings should be okay for DVD content up to about 70 minutes.
    If you need to use VBR for longer media, search this forum for Mark’s bit rate calculator!
    When you start messing around with the default templates without understanding the consequences, you can get yourself in a world of strife.
    If you are still experiencing flicker, are you mixing DV with HDV or AVCHD events?
    Are you cropping your DV footage? Cropping will result in some unusual artifacts, especially during motion/panning.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Troy Musson
    August 10, 2011 at 4:29 pm
    thanks for your reply and help, I changed the i frames to 15 on recommendation of the vegas software as i was getting motion defects and it seemed to cure that i think, i have images at the end of the video and even with interlace flicker ticked the images were still flickering, but i will try your settings thank you.
  • Nigel O’neill
    August 10, 2011 at 9:24 pm
    Those are the settings I use for my clients. No complaints received to date.
  • David Jackson
    February 24, 2012 at 10:25 pm
    I am too trying to render out an m2v file for DVD authoring and getting major flicker (to black). I have never had this behaviour before. 🙁 I have just moved to Vegas 11. The project has been rendering fine, it just cropped up last night. Nigel or someon can you help?? Ta David
  • Nigel O’neill
    February 24, 2012 at 10:59 pm
    This is a very old thread, and no one is likely to respond. Start a brand new post and you might get a response from the guru’s. I am stumped.
    Provide details of your source format, and where the problem is occuring. e.g. it is playing fine and happens after a certain amount of time has lapsed.
    Is it only happening during transitions?
    Is it images it is happening to, such as during pan and crop?
    Are you mixing formats e.g. AVCHD or HDV or DV?
    Have you ticked ‘Adjust source media to match project or render settings’ and it is still happening.
    Are you doing a CBR or VBR encode? Are you doing a 2 pass VBR encode?
    What ‘render as’ template are you using? Many posters work with NTSC, and some advice is NTSC specific.
    All this information is helpful to the guru’s.
  • Harry Singh
    May 4, 2014 at 11:40 am
    hi. i am also facing some problem related to flickring. i am making wedding video. myall clip is 1920×1080- 25 fps. when i make dvd in 720×576. and when i play dvd there are very flickring on the edges of subject specuially when its moving. exampple people are dancing there are zigzag lines around there movement. what i try to reduce flickring from switch tab. it remove flickring but gave me very blur result. there is any way to solve this issue. pleas help
  • Nigel O’neill
    May 5, 2014 at 11:26 am
    What is your deinterlace method under project properties? blend fields or interpolate? You may need to set it to interpolate.
  • Harry Singh
    May 7, 2014 at 6:45 am
    thnx for this help. i used blend method .and its really help me. beside this there is no any other setting to make more sharp these edges.
  • Greg Frediani
    October 28, 2016 at 11:39 pm
    Hello Nigel. Thanks so much for the help. I am in edge-flicker hell. I have read and watched various proposed solutions. Nothing has totally worked.
    I am in Vegas Pro 8 on a government computer. I indeed am getting “unusual artifacts” during cropped footage. What to do?
    Source footage: digital video of old WWII color home movies.
    Cropped: to Widescreen, and some motion is required to feature the part of the image I want to feature.
    Effects: I am using Brightness/Contrast, Color Correction, Color Balance, and Sharpen.
    Output: “Rendering” to .WMV and to .MP4, default NTSC widescreen. The “artifacts” is a white border along the top of the cropped video, which then sometimes flickers. Unacceptable, but is there a solution????
    Greg (Final Cut vet, but new to Vegas)
  • Eric Clinch
    October 29, 2016 at 1:13 am
    What I’ve done in similar situations is place a very narrow black strip on a track above the others to cover up the flickering edge. It only needs to be a couple of pixels high. Okay it reduces the visible image slightly but who will notice and it’s better than the flicker.
