Activity Forums Adobe Premiere Pro Interlacing and Jumping issues. PC based CS5
  • Interlacing and Jumping issues. PC based CS5
    Posted by Steve Mac kenzie on April 22, 2012 at 9:14 pm
    I have two clips that make a feature length movie that have been encoded for me at a post house and I just need to put them together and burn them to DVD. This issue is that I can see the interlacing in the footage during certain scenes and through transitions. The title crawl at the end jumps a bit as well. The specs for the clips are below. The eventual destination is DVD through Encore. I have done mostly episodic work batched from tapes so I have never had to deal with this. So you have advice for the settings? Should I attempt an update?
    Here is the clips properties.
    Quicktime Movie
    Image Size 720 X 486
    Pixel Depth 24
    Frame Rate 29.97
    Average Data Rate 27.2 MB/second
    Average Frame Rate 29.98 FPS
    Uncompressed 10 bit.
    Thank you for your time and your help!
    Thank You for your input!
    Steve Mac kenzie replied 14 years, 4 months ago 1 Member · 2 Replies
  • Steve Mac kenzie
    April 23, 2012 at 12:17 am
    I currently have Quicktime V 7.6.8 (1675) should I possibly update this? I usually never update unless I have to and I do not know if 7.7.1 is compatible with CS5.
    Thanks again!
  • Steve Mac kenzie
    April 23, 2012 at 1:18 pm
    Hello, Hello, Hello… Is there anybody out there?
