Activity › Forums › Apple Final Cut Pro Legacy › Interlacing across edits
Posted by Chris Farrington on September 9, 2008 at 4:14 pmHi all,
We have a project shot on film.
Transferred to DV.
We just hooked up a flat panel TV to the computer using a digital to analog converter.
When we watch the TV, we see the interlacing.
When we go frame by frame, it jumps from one interlaced frame to the next interlaced frame (has that weird jagged horizontal line look).
It also makes the edits pop like crazy because it 1/2 the interlaced frame of the outgoing clip is left as an artifact on the incoming clip.I don’t want to de-interlace the many many hours of footage I have. Any suggestions?
Thanks.
Jeremy Garchow replied 18 years ago 4 Members · 13 Replies -
David Roth weiss
September 9, 2008 at 4:25 pmAs you have discovered, AJA and Blackmagic are in business with good reason. If you have the money to shoot film, you certainly should not be skimping on the hardware you need to display and edit it properly.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Chris Farrington
September 9, 2008 at 4:43 pmI agree.
This feature is getting all sorts of grants and breaks to happen, so skimping is the name of the game, sad to say.
However, I did look up one name you mentioned “Black Magic” and found they have a card that outputs an HDMI signal. If I installed that and went HDMI into the TV, would the interlace issue be solved? -
David Roth weiss
September 9, 2008 at 4:51 pmChris, I haven’t tried out their Intensity card myself, but it’s certainly worth a try. Go over to the Blackmagic Forum and see what users are saying over there. Also, I would recommend going on Ebay to see if you can find a good deal on a BM Extreme card, which will give you many more options.
David Roth Weiss
Director/Editor
Jeremy Garchow
September 9, 2008 at 5:08 pmLet’s back up a second. You shot on film, telecined to dv. When you brought in the dv footage, did you remove the pulldown? What frame rate is your timeline?
Jeremy
Chris Farrington
September 9, 2008 at 5:19 pmWe’re taking over for another editor, so I can’t be sure what they did when they brought it in.
The frame rate of the sequence is 29.97.The timecode has a “:” and not “;” in it. I forget which is which.
Tom Wolsky
September 9, 2008 at 5:22 pm: is non-drop frame. That’s what telecine usually converts to.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Jeremy Garchow
September 9, 2008 at 5:35 pmOkay Chris. You are essentially editing in an interlaced environment. If you want to be in a pure progressive environment, you need to remove the pulldown from your source footage and work @ 23.98.
You can also change your seq. settings as they are now to render with a field dom of ‘none’. That will make your render progressive BUT the motion characteristics might look weird as you will still have pulldown frames in your source material (you will be creating 30p rendered material from 24p with pulldown material). You have to keep your frame rate @ 29.97 in this case.
Jeremy
Chris Farrington
September 10, 2008 at 7:16 pmHere’s the solution we’ve come to thus far.
The issue is that DV is inherently interlaced and client monitors are a problem when you’re coming out of a computer via firewire.
However, if we were to come out of a DVI port, like the ones the computer monitors are attached to, then the signal would not have that compression necessary for getting it through firewire.So, if we go DVI out with an HDMI attachment to a TV, then our signal might get rid of that jagged look. At the very least, it will be much sharper.
So, we bought a video card with two DVI outputs. We have to upgrade to Leopard to make it work, though.
The solution came up because we thought “well, these computer monitors don’t show any interlacing, maybe a DVI slot where the signal comes straight from the video card might work.”
Of course, the only true solution would be to also buy a Progressive Scan monitor like the ones we currently have. But that’s a lot of money.
Jeremy Garchow
September 11, 2008 at 12:10 amUhh dude? Did you change your sequence settings to none? If the footage is from film, it’s not inherently interlaced. It is 24psf with 3:2 pulldown so, roughly 66% of your footage is progressive, and roughly 33% is interlaced. You need to remove the pulldown to get rid of the interlacing. It’s that simple.
[Chris Farrington] “However, if we were to come out of a DVI port, like the ones the computer monitors are attached to, then the signal would not have that compression necessary for getting it through firewire. “
The dv compression is already there, FCP is simply playing it back.
[Chris Farrington] “So, if we go DVI out with an HDMI attachment to a TV, then our signal might get rid of that jagged look. At the very least, it will be much sharper.”
So you are going to upconvert DV to HD and you think it’s going to look sharper?
[Chris Farrington] “The solution came up because we thought “well, these computer monitors don’t show any interlacing, maybe a DVI slot where the signal comes straight from the video card might work.” “
That’s because FCP is showing you a low res proxy of the original image. Set your canvas to 100% and you will see the interlacing.
[Chris Farrington] “Of course, the only true solution would be to also buy a Progressive Scan monitor like the ones we currently have.”
No, it’s not.
Chris Farrington
September 11, 2008 at 12:18 amIs this changing the project settings, or merely the playback settings? My concern is that we will have to master back to a Digital Intermediate so I don’t want to mess with any important frame information. There are no key codes. All the time-code relates back to another tape that has the key codes burned in. Do you know what affect your solution might have on the timecode/future EDLs?
