Activity › Forums › DVD Authoring › Interlacing
Interlacing
Posted by Sean Simms on January 6, 2012 at 9:20 pmI am using DVD studio pro 4. I imported a fcp mov reference file and it made an mpeg file….when I play it in the DVD Studio Pro viewer area it looks fine but when I put it into the simulator it plays with interlaced lines. How can I change this?
Sincerely,
Eros Salvatore
http://www.erossalvatore.comChris Tompkins replied 14 years, 8 months ago 3 Members · 7 Replies -
Michael Sacci
January 6, 2012 at 9:32 pmQuality cannot be judged in Simulator, test a build in DVD Player software or better burn a disc.
You need to give more info. What did you make the mpeg movie? Is it a m2v? What is your source files?
Sean Simms
January 6, 2012 at 9:37 pmyes its an m2v…dvd studio pro made it automatically after I imorted the fcp reference file (not self-contained)
Sincerely,
Eros Salvatore
http://www.erossalvatore.com -
Sean Simms
January 6, 2012 at 9:42 pm -
Michael Sacci
January 6, 2012 at 9:43 pmIf you want real answers give real information and settings. If you cannot there is no way to help you.
Did you test the way I said?
Sean Simms
January 6, 2012 at 9:48 pmWhat settings do you want?
The source is mini-dv SD 720×480, DVCPRO NTSC, 29.97 fps, Lover (Even) Filed Dominance (I tried changing Field Dominance to None but it didn’t help.
Just finished the burn, everything is okay…….
Chris Tompkins
January 18, 2012 at 1:05 pmReference or self-contained makes no diff.
Computer screens are not meant to display interlaced material correctly.
Don’t judge your video on the computer screen.Chris Tompkins
Video Atlanta LLC
