Activity › Forums › Panasonic Cameras › interlaced to progressive
  • Jeremy Garchow
    November 21, 2008 at 6:48 pm
  • Jaenet Guggenheim
    November 21, 2008 at 7:58 pm
    hi jeremy,
    thank you for showing me how to change 1080i 24p from 29.97 to 23.976 interlaced.
    can you show me how to change 1080i 24fps to a true 24P?
    thanks,
    jaenet
  • Jeremy Garchow
    November 21, 2008 at 8:01 pm
    Once you remove the pulldown, you will have 24p material. There is no 24p interlaced. Hyper technically, it’s 24psf (as that’s how the image is scanned on recording) but for all intents and purposes it’s 24p.
    Jeremy
  • Jaenet Guggenheim
    November 21, 2008 at 8:17 pm
    okay jeremy,
    it sounds like there is a way to convert the 29.97 1080i 24P to real 24P.
    is that what you are telling me?
    can you give me the baby steps to achieve this?
    i understand the export compressor step. after that, i don’t know what to do.
    thank you,
    jaenet
  • Jeremy Garchow
    November 23, 2008 at 12:50 am
    [jaenet guggenheim] “can you give me the baby steps to achieve this? “
    https://forums.creativecow.net/readpost/8/995940
  • Jaenet Guggenheim
    November 23, 2008 at 1:38 pm
    thanks jeremy,
    this helps. thank you. my footage saysDVCPRO 1080i30p for compressor — note the 30p.
    should i still use the DVCPRO 1080i60 setting for the decompressor?
    and this is a stupid question, but i can not find the encoder button. is there a place to click to make that appear? it isn’t even in the help menu.
    thanks,
    jaenet
  • Jeremy Garchow
    November 23, 2008 at 3:41 pm
    [jaenet guggenheim] “my footage saysDVCPRO 1080i30p for compressor — note the 30p. “
    Are sure you shot 108024p?
    Encoder button is the second little button in the inspector:
