Activity Forums Apple Final Cut Pro Legacy Interlaced to Progressive
  • Interlaced to Progressive
    Posted by Smith Glover on July 30, 2010 at 11:19 pm
    I am trying to help a client who has the following problem: Their camera guy shot half of their BTS footage at 1080i 59.94 and the other half at 720p 23.98. They want the final export to be 1080 p 23.98- the problem of course being that half the footage is interlaced. The footage was shot on a Panasonic HPX-500 (if that’s important at all). Is there a relatively easy fix for this? Is there a program that can convert, at least reasonably well, interlaced to progressive? Any help would be greatly appreciated.
    Smith Glover replied 16 years, 1 month ago 2 Members · 2 Replies
  • Michael Sacci
    July 30, 2010 at 11:52 pm
    Magic Bullet Frames does a good job with this. And you are not just de-interlacing you are changing the frame-rate which is also something that MB Frames does well.
    You can test just using Compressor and turning on Frame Control.
    Either way to do a good job you it will require a lot of time.
  • Smith Glover
    July 31, 2010 at 12:02 am
    Thanks Michael- that’s very helpful.
