Activity › Forums › Broadcasting › Interlaced to broadcast
  • Interlaced to broadcast
    Posted by Christofer Wetterholm on November 17, 2009 at 5:25 pm
    Hello!
    I could really need some help to clear things out..
    I´m working on a project wich is going to be broadcasted on tv in sweden,norway and denmark
    The footage i recieved from the client is interlaced PAl. UFF 25fps 1024 576
    My job is to do the graphics and text in after effects and then render out a master file (Mpeg 2 and Quicktime)) to the broadcaster.
    What is the best workflow so i get the highest quality possible?
    Is it best to interpret the footage as UFF, do all the animation work and then render out the finished movie with fieldrender on. Set to UFF.
    Or is it best to render it with fieldrender set to off.
    If i understand everything correct then the first choise is better but i don´t know and i hope some of you do!!
    /Christofer
    Maurice Jansen replied 16 years, 10 months ago 2 Members · 1 Reply
  • Maurice Jansen
    November 21, 2009 at 11:16 am
    your correct
    if you use the last option all the things you ad will studder
    greet
    Maurice
    People saying they don’t make mistake’s often make nothing at all!
