Activity › Forums › Adobe After Effects › Interlaced or de-interlaced footage for compositing in AE?
Posted by Uwe Lansing on March 1, 2006 at 5:54 pmHi,
what is the better way for compositing (rotoscoping, effects….); de-interlaced or interlaced footage
regards
UweUwe Lansing replied 20 years, 6 months ago 6 Members · 7 Replies -
Mark
March 1, 2006 at 6:02 pmI would say that if you interpret the footage correctly in After Effects it doesn’t really matter.
Mark
Steve Roberts
March 1, 2006 at 6:10 pmBut if you rotoscope interlaced footage, you need to separate fields (file>interpret>main) then drag the clip into a comp whose frame rate is twice that of the footage. This way you’ll be rotoing on every field.
In the case of 29.97 fps video, the comp should be 59.94. Then you render at 29.97.
Steve Freebairn
March 1, 2006 at 7:19 pmfor the best results without having to rotoscope each field individually, it is much better to use progressive footage.
Aptjel
March 1, 2006 at 7:29 pmHi Uwe,
when working with interlaced footage in a roto situation try this:
1]import & interpret footage
2]place footage in Comp
3]go to the compostion settings and change frame rate and duration (I work In Pal so from: 25 Fps to: 50 fps in effect your doubling frame rate)what you are doing is looking at every instance of movement(every field) the benefit of this is so you can see and make adjustments on the fly which sometimes can be hidden on a progessive scan monitor this will give you more temporal resolution when Rotoing.
hope that helps,
regards
Josh
Uwe Lansing
March 1, 2006 at 7:34 pmThanks for your answers. On this site it seems, that the author favors the method with de-interlaced footage:
https://www.animemusicvideos.org/guides/avtech/interlacedvsprogressive.htmlHowever, the advice of Steve is very helpful
Espnetboy3
March 1, 2006 at 8:31 pmIs there any way that looks good to deinterlace footage straight in AE? Steve what you were saing about interpreting would you need 2 layerse one with even and one with the odd fields?
