Activity Forums Adobe After Effects Interlaced ghosting Problem in AE 6.5
  • Interlaced ghosting Problem in AE 6.5
    Posted by Lance1 on July 4, 2006 at 3:12 am
    I have a ghosting interlaced problem which looks to me to be an inherent design flaw.
    Specifically, after I render DV footage and play it back to my camera, there is a small ghost aroung the moving parts of the image. I have tried everything I can think of to get rid of it.
    My source footage is DV (Canopus) with Lower Field First (LFF). I checked the Interpret Footage setting and it is set to LLF. (Actually, I have tried both LLF and Off). I then Make Movie, setting the Field Render to LLF (again, I tried both LLF and off) and I have tried No Compression and Canopus DV compression (this was a total of 8 tests). The resulting file plays fine on my PC, but when I use Raptor Video (or Premiere, it doesn’t matter which), I see a slight ghosting on the moving parts of the image. I do not see this with the original footage.
    Any ideas how to solve or is this indeed a design flaw?
    Lance
    Nc66blkman replied 20 years, 2 months ago 2 Members · 1 Reply
  • Nc66blkman
    July 4, 2006 at 3:00 pm
    I don’t think it’s an “inherent design flaw,” as you suggest, because none of the rest of us have had who work in DV.
    I think it’s fairly safe to say that it’s localized to your machine.
    I wish I could think of a way to solve it for you but I have no ideas at the moment.
    Charles
