Activity Forums Adobe Premiere Pro Interlaced clips to DVD without black lines?
  • Interlaced clips to DVD without black lines?
    Posted by Rich Franklin on December 12, 2012 at 10:59 pm
    I have an interlaced timeline in Premiere that contains progressive clips from a dSLR and interlaced clips (DVCPro50).
    In Encore I want to output it as MPEG2 for DVD.
    Can somebody tell me how I get a high quality result on DVD – I mean NO BLACK LINES from the interlaced footage.
    I have been told that by burning it to DVD and playing on a TV, the interlacing will not show, but so far this is not the case.
    I do not want to use “Deinterlace” as the quality is too bad.
    Really, I need to know a good workflow for DVD from Premiere.
    Thanks.
    Ann Bens replied 13 years, 9 months ago 3 Members · 5 Replies
  • Walter Biscardi
    December 13, 2012 at 1:38 am
    If your timeline is interlaced, you need to create an MPEG-2 file that matches your original timeline. So if it’s interlaced Upper Field First, then your MPEG-2 file has to match.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “This American Land” – our new PBS Series.
    Blog Twitter Facebook
  • Rich Franklin
    December 13, 2012 at 10:05 am
    Thanks.
    The video clips are from DVCPro50 which I think is lower field first. Do I still select Upper field first?
  • Ann Bens
    December 13, 2012 at 12:52 pm
    Your project settings should match your footage.
    Check the footage for fields in
    https://mediainfo.sourceforge.net/nl
    If the dvcpro is lower fields its wise to make a SD timeline with lower field (there is a ready made preset) and drop the HD? dslr into this timeline
    Export to mpeg2-dvd lower field (this will give you two files: 1 video file and 1 audio file)
    Import this in a DVD Encore project
    Author and burn.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Walter Biscardi
    December 13, 2012 at 1:00 pm
    If it’s DV50 NTSC then the standard would be lower field first.
    If it’s DV50 PAL then the standard would be upper field first.
    If your timeline is NTSC HD 1080i then you’ll be upper field first.
  • Ann Bens
    December 13, 2012 at 1:02 pm
    In PAL-land DV is also lower field first.
    If one captured dv with the Matrox codec then it would be upper (that used to be such a pita)
