Activity Forums Adobe After Effects Interlace or Progressive for Canon 7d
  • Interlace or Progressive for Canon 7d
    Posted by Tim Vanbrackle on August 13, 2012 at 8:05 am
    Hello, I’m stuck and need your help. It’s an interlace / progressive issue and I’ve looked everywhere for answer, it’s got to be somewhere but I don’t see it.
    I’ve imported some 1080 quicktime mov files into after effects and noticed the interlacing. I’ve never changed the fields on video before and just realized that it’s going to be a huge issue if I’m wrong (rotoscoping)
    I will also be importing the ae project into premiere and mixing that with more footage from 7d.
    questions:
    what should the project setting for AE be?
    Should I seperate the fields?
    What should the project setting be for premiere? (i use the dslr setting )
    when i import the ae project should I interpret it differently in premiere?
    With all the mixmatched footage I’m just confused. Your help is greatly appreciated.
    Tim
    Chris Brett replied 14 years, 1 month ago 2 Members · 1 Reply
  • Chris Brett
    August 13, 2012 at 11:40 am
    Hi–
    — mostly when rotoscoping I leave fields interlaced but if the action is fast or close to the camera you may need to de-interlace to get a clean edge —
    —- if rotoing by hand I would avoid deinterlacing unless you have to because its twice the work however am not familiar with this particular format or the auto select thats in AE nowadays …. if the auto gives a pretty clean edge it might not matter if you have twice as many ‘frames’ to deal with.
    … so my guess is that it depends on the footage a bit but will be very interested in what the others think as well……..
    chris brett /// uk
