Activity Forums Adobe After Effects Interlace issues on CRT television
  • Interlace issues on CRT television
    Posted by Rob Hindley on September 9, 2009 at 9:43 pm
    I have prepared an ad for our national broadcaster (TVNZ). They require an mpeg2 file to play out. Video looks great (shot XDCam and edited in Apple ProRes 422 in FCP). However the clients logo is a box with white outline on a black background. Played on an HD televison the vertical edges look fine but on the CRT I get quite a bit of wavy distortion.
    Is there a quick fix for this?
    I guess it is the high contrast between the white and black that freaks the tv out.
    Scott Novasic replied 17 years ago 3 Members · 2 Replies
  • Joseph W. bourke
    September 10, 2009 at 1:12 pm
    The quick fix is a small amount of blur on the area that’s giving you a problem. There’s no set amount – it requires experimentation, but it usually works.
    Joe Bourke
    Creative Director / Multimedia Specialist
    B&S Exhibits and Multimedia
    bs-exhibits.com
  • Scott Novasic
    September 10, 2009 at 9:26 pm
    you can also see if your allowed to ‘beef’ up the thickness of the stroke itself on the logo. The plug in, among many that helps this, is the ‘reduce interlace flicker’ plug.
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
