Activity Forums Avid Media Composer interlace fury
  • interlace fury
    Posted by Alex Harding on July 23, 2005 at 1:06 pm
    hi there
    me again. still on avid xpress pro hd
    my project is all set up as 25p, all my footage has gone through combustion and is imported as full frame tiff sequences. its definitely all set up for progressive scan, but avid insists on interlacing anything i export, even tiffs.
    i cant find any options about field rendering in the compression settings.
    can anyone help?
    thanks,
    alex
    Michael Phillips replied 21 years, 1 month ago 2 Members · 1 Reply
  • Michael Phillips
    July 23, 2005 at 8:57 pm
    Are you sure that the original render in Combustion was done progressive? There are no settings for progressive because the project type itself will always render and export progressive by default.
    If it is a bug, what version are you running?
