interference lines on typewriter text.. and on edge of graphic
Hi
Ive a problem with interference lines on typewriter text and the edge of a freeze frame graphic which has a zoom quicktime transition effect on it.
This problem is not so visible on the timeline but is visible on the exported file . Is this an export problem, any suggestions how I should export to avoind this or do I need to do something to the original ?
I have to deliver to the client if possible today but would love any suggestions you could make.
thanks
Sitar Rose
