Activity Forums Adobe Premiere Pro Interface colors Premiere Pro 2014
  • Interface colors Premiere Pro 2014
    Posted by Paul Budline on March 13, 2015 at 12:43 pm
    I can barely read the blue time code numbers, especially in the video effects panel of an individual clip. How can these be changed to yellow or white or some other color? Thank you.
    Robert D’alexis replied 11 years, 6 months ago 2 Members · 3 Replies
  • Robert D’alexis
    March 13, 2015 at 7:13 pm
    [Paul Budline] “How can these be changed to yellow or white or some other color?”
    The short answer is, there is no way you can change them although that may change with the next version of Premiere which will be unveiled shortly before NAB 2015.
  • Paul Budline
    March 13, 2015 at 7:41 pm
    Nevertheless, I may have some bad setting because I can almost not see the blue numbers and there’s no way this release would have been approved. I wonder if I might change some monitor setting or something like that.
    Thanks again
  • Robert D’alexis
    March 13, 2015 at 8:28 pm
    Well, in that case you can go to Preferences and play around with the Appearance slider to see if that makes numbers more legible.
