Activity Forums VEGAS Pro Interesting Problem with DVDA and MacDrive Utility
  • Interesting Problem with DVDA and MacDrive Utility
    Posted by Joe Mantaratz on January 8, 2010 at 2:01 pm
    I use MacDrive to be able to cross utilize my MAC drive for the PC. It behaves exactly as only other drives do in all applications, except DVDA. When I attempted to burn a DVD it would tell me that I did not have permission to check with the administrator. My prepare and write folder were pointed to this drive so I suspected this was the problem. Sure enough I changed the prepare destination to my desktop and it worked fine. Point of note, you will get this same message if you do not have MacDrive installed and you attempt to write tot the drive. Reading and copy from the drive does not cause a problem. Anyone ever have this problem or know of a solution? Not a huge issue but a curious one.
    Joe
    Joe Mantaratz replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
