Activity › Forums › Cinematography › Interesting depth of field device
  • Bob Woodhead
    June 22, 2005 at 2:08 pm
    WOW! Now that was a fantastic display of ingenuity! Looks like the results were quite impressive.
  • Mitch Gross
    June 30, 2005 at 3:16 am
    This has been around for a little while now. I believe the website creator eveolved the item into an actual product. If it’s not him then it is a design of a very similar nature. It’s called the Micro35 and sells for an astoundingly low $500. Properly machined and built to tight tollerances using a real groundglass, not fiberboard and a plastic CD blank, so it has far better performance than the DIY version. I’m probably going to pick one up soon having seen it in person and impressed.
    Mitch
