Activity › Forums › Apple Final Cut Pro Legacy › Interesting Compressor Message
  • Interesting Compressor Message
    Posted by Lee Berger on October 30, 2009 at 2:54 pm
    This is not a big issue, merely an annoyance. Lately when I start Compressor for the first time each day I get the following message:
    The last Compressor batch was submitted by a different user.
    This batch may have finished or may still be in process. Click Reset to delete all unfinished jobs in the batch and continue opening Compressor. Click Quit to stop opening Compressor and allow any unfinished jobs to continue. You can also open the Batch Monitor (located in the /Applications/Utilities folder) to verify the status of any jobs still in process.
    I checked the Batch Monitor and there are no unfinished jobs. I’m the only user. I have been selecting Reset continuing on as per usual. Like I said it’s not a major issue, just an annoyance. Anyone else seen this? Thanks.
    Lee Berger
    http://www.leebergermedia.com
    Rafael Amador replied 16 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    October 30, 2009 at 3:15 pm
    Hi Lee,
    I have exactly the same message just few days ago.
    I’ve never saw that before.
    I’m the only user too.
    It happens after a hang were Compressor didn’t submit the Batch.
    I ran “Compressor Repair’ and after I’ve got that message.
    What you need is to clean the “History” window.
    may be a job that have been improperly stopped or so.
    Hope this helps.
    cheers,
    Rafael
    http://www.nagavideo.com
  • Lee Berger
    October 30, 2009 at 6:24 pm
    Thanks Rafael,
    I cleared the history window, but that did not fix the problem. Thanks anyway.
    Lee
    Lee Berger
  • John Fishback
    November 1, 2009 at 8:29 pm
    Try Compressor Repair as Rafael suggests. It might help.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Lee Berger
    November 1, 2009 at 9:03 pm
    Thanks John. I think running Compressor Repair caused the problem for both Rafael and me.
    [Rafael Amador] “I ran “Compressor Repair’ and after I’ve got that message.”
    Unfortunately his suggestion about clearing the history did not help. Perhaps I should try running Compressor Repair again.
    Lee
    Lee Berger
  • Rafael Amador
    November 2, 2009 at 2:53 am
    [Lee Berger] ” Perhaps I should try running Compressor Repair again. “
    Yes. Do it Lee.
    I’ve run it again and now it works fine.
    However cleaning the History Window is a good policy.
    I used to have problems with jobs that I sopped but Compressor re-started whenever I opened the application.
    Best,
    Rafael
  • Jon Chappell
    November 2, 2009 at 7:34 am
    Which version of Compressor are you running? Did you run Compressor Repair on a non-administrator account?
  • Rafael Amador
    November 4, 2009 at 4:49 pm
    Hi John,
    Sorry I haven’t answered before.
    I’m running Compressor 3.05 in a MBP.
    I’m the only user in my computer and I have no other accounts.
    Curiously the Compressor message (can not fully remember it) mentioned something about other accounts.
    Best,
    rafael
