Activity Forums Adobe After Effects Interesting AE Quiz
  • Interesting AE Quiz
    Posted by Roland R. kahlenberg on July 7, 2009 at 1:59 am
    The Timeline Indicator is currently set at 00;00;05;20
    After clicking on the timecode display, what do you type if you want to
    a) move to a specific time such as 00;00;12;22
    b) move 22 frames forward
    c) move 22 frames back
    Cheers
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
    Brian Charles replied 17 years, 2 months ago 4 Members · 5 Replies
  • Brian Charles
    July 7, 2009 at 3:30 am
    Interesting Quiz RoRK. I thought I knew until I tried it.
    A) To go to 00;00;12;22 type 1222 or 12.22
    B) 22 frames forward type + 22
    c) 22 frames backward type +-22 **This one got me** plus minus 22
  • Stuart Elith
    July 7, 2009 at 3:58 am
    this is mostly just academic for me, I don’t tend to use the timecode jump… but i had a look anyway 🙂
    I was expecting to click on it (so it brings up the box), then put my cursor after the last number and type something like “+ 0.22” to jump forward 22 frames. That didn’t work at ALL, gave some very large changes.
    I learnt that if you don’t deselect the timecode (i.e when you press the button, it brings up the box with the timecode selected, LEAVE it like that) then type +0.22 or whatever, then it works as expected.
  • Giriraj Bakale
    July 7, 2009 at 6:19 am
    Hi friends….
    i saw afterfx works like this for me…
    when we type numbers til 99 it goes for frame but if you want to jump to sec i just type 100 for 1 sec, 200 for 2, and on and on…
    Giriraj Bakale
    Post Pro
    INDIA
  • Roland R. kahlenberg
    July 7, 2009 at 2:31 pm
    [Brian Charles] “c) 22 frames backward type +-22 **This one got me** plus minus 22”
    After using AE for such a long time and trying a few possibilities I actually gave up on this one until a student experimented a little and found out that +- worked to move the CTI (current time indicator) backwards.
    It all boils down to AE allowing for the CTI to move to a negative time value. While it is at times useful for layer in-points to start at a negative point in time, I really don’t see any benefit for the CTI itself to move into a negative timecode.
    If the CTI was prevented from moving into this negative area, then typing -22 would correctly and intuitively move the CTI back 22 frames.
    Do you guys see any use for the CTI to move into negative territory?
    Cheers
    RoRK
  • Brian Charles
    July 7, 2009 at 2:55 pm
    [RoRK]It all boils down to AE allowing for the CTI to move to a negative time value…
    None at all. It was counter-intuitive and useless to me.
