Activity Forums Adobe Illustrator Interested in recreating this spiral affect
  • Interested in recreating this spiral affect
    Posted by Chris Charles on August 6, 2017 at 4:17 am
    Hello everyone,
    I’m trying to recreate this spiral effect with 4 letters in a square. The letter starts right side up and gradually shrinks in size as it spirals inward to the center. And in each corner, i guess the direction of the spiral will have to change.
    Thank you
    Vincent Rosati replied 9 years, 1 month ago 2 Members · 1 Reply
  • Vincent Rosati
    August 6, 2017 at 8:06 am
    Start with expanded text.
    Make a big M and a little M.
    Then do Object > Blend > Make. Then Object > Blend > Blend Options: Specified Steps: 20 or whatever, Orientation: Align.
    To achieve the curve, make a path that approximates the spiral, then select the blended text and the new path then Object > Blend > Replace Spine.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
