Activity › Forums › Adobe After Effects › Interested in creating a delayed blend (in Illustrator) effect with motion
  • Interested in creating a delayed blend (in Illustrator) effect with motion
    Posted by Calum Campbell-coles on October 4, 2019 at 7:41 pm
    Hi guys, I know this is a long shot but I’ve come across this animation from estúdio arco as part of their 36 days of type and I just wanted to get some info on how I would be able to achieve something similar?
    The only way I can describe it is a blend effect from Illustrator and the layers are following the top layer with a slight delay.
    Reference link: https://mir-s3-cdn-cf.behance.net/project_modules/disp/879f9878360081.5ce71b11b4c94.gif
    I’ve not explored expressions before and I reckon that might be my best option looking at other threads.
    Any direction to go and research would be much appreciated.
    Fabian Bosman replied 6 years, 9 months ago 2 Members · 4 Replies
  • Calum Campbell-coles
    October 5, 2019 at 6:30 pm
    After a little bit of digging, I’ve found https://forums.creativecow.net/docs/forums/post.php?forumid=2&postid=1036368&univpostid=1036368&pview=t very helpful.
    This is the code I’m using.
    linear(effect("Completion")("Slider"),0,100,effect("Point A")("Layer").transform.position,effect("Point B")("Layer").transform.position)
    I’ve decided to make all the shapes in Illustrator (6 triangles in this instance) and I’m now using them to follow the Point A null while the Point B null is still. How would you apply a valueAtTime to delay the triangles to create a ripple delay effect?
    I think my method is pretty botched but I’m learning expressions for the first time at least…
    October 5, 2019 at 6:44 pm
    I also forgot to mention that all my triangles are on this path with different “Completion” values so that I can create the ripple effect. It’s a bit of a manual task but I was searching for ways to add a slider to how much the shape is affected by a parent in position and ended up on the link above.
    October 5, 2019 at 7:40 pm
    I feel like this thread is all me haha.
    I’ve figured it out with this:
    delay = 1.5; //number of frames to delay
    d = delay*thisComp.frameDuration*(index - 1);
    effect("Point A")("Layer").transform.position.valueAtTime(time - d),
  • Fabian Bosman
    December 9, 2019 at 11:03 am
    I’m looking for the same effect.
    Where do you put the expression? In the position of the duplicate layers?
    Can you share your setup?
