Activity Forums Adobe Premiere Pro Intentional Jitter
  • Intentional Jitter
    Posted by Tim Taylor on May 18, 2008 at 7:41 pm
    I am trying re-create the ‘jitter’ that you get before a clip is rendered.
    The effect I’m looking for is as if there is an intentional micro pause with each frame. I can’t explain it better than that!
    If you have a clip in PP CS3, black and white it, then play it before rendering, and see the effect you get.
    That’s what I want…. can anyone suggest a method?
    Vincent Rosati replied 18 years, 3 months ago 2 Members · 4 Replies
  • Vincent Rosati
    May 21, 2008 at 12:32 am
    Hmmm, maybe if you could post a reference or maybe a link to a youtube or something.
    It’s almost like you’re describing reducing the frame rate by half, say 30p to 15p. Than dropping the 15p back in a 30p project for the same duration of the original clip.
    Or maybe a sort of Max Headroom thing…
    https://www.youtube.com/watch?v=aZgFXdqDCRM&NR=1v
    Vince
  • Tim Taylor
    May 21, 2008 at 7:03 am
    If you could explain to me how to do that frame rate ‘thing’, then I’ll give it a try and see if it is the effect i want.
    Max Headroom is certainly something similar to what I want, but I don’t have any of my own examples.
    All I can say is I want the effect like that which I get when reviewing an un-rendered piece of footage on my PC!
    FWIW…. I’m using PAL Widescreen 48Khz as my preset.
  • Tim Taylor
    June 2, 2008 at 10:17 am
    Can anyone else help with this please?
  • Vincent Rosati
    June 2, 2008 at 11:14 pm
    Without seeing an example, the only other thing I can think of is dropping frames. Just cutting out random frames or groups of frames, than closing the gaps by stretching the clips or compacting the runtime, to create a stuttering effect.
    Maybe start a thread on the Premiere Pro or After Effects forum.
    Vince
