Activity Forums Blackmagic Design Intensity to Dell
  • Intensity to Dell
    Posted by William Edwards on November 2, 2011 at 3:17 am
    Hello,
    I was wondering if I could hook up the Blackmagic Intensity to the Dell Ultrasharp U2410 24″ LCD monitor. I am going to be working on an SD feature, editing and coloring.
    Can I do that through the component connections?
    Kristian Lam replied 14 years, 10 months ago 2 Members · 3 Replies
  • Kristian Lam
    November 3, 2011 at 2:28 am
    Hi William,
    Yes, that will work. You can use the Dell like a regular component display via the Intensity Pro’s component analog output.
    regards
    Kristian Lam
    Blackmagic Design
  • William Edwards
    November 3, 2011 at 4:18 am
    Is there a Blackmagic device similar to the Intensity that doesn’t have a Thunderbolt connection? Say, if I have a MacPro?
  • Kristian Lam
    November 3, 2011 at 6:43 am
    [William Edwards] “Is there a Blackmagic device similar to the Intensity that doesn’t have a Thunderbolt connection? Say, if I have a MacPro?
    You can use the Intensity Pro which is a PCIe card.
    regards
    Kristian Lam
    Blackmagic Design
